Buzzing is killin me
radio noise compressor will not fix the problem I can almost bet that lxman1 is right. It is a common problem in the fox bodys replace your fog light switch and the whole directional assembly. You can purchase this thru latemodel restoration and its a cheap fix. you can turn radio off and turn headlights on wiggle the directionals and the foglight switchout if the lights turn off or flicker theres your problem or if after being on for awhile then the flicker or cut out its it. Is it a stock radio? If not check how its wired most people just tie in anywhere which is not good
