jasonr |
11-08-2009 12:56 AM |
clutch cable
so i recently had a clutch change. i bought a stage 2 performance clutch along with a new flywheel. I had this garage install it for me. After that at first i noticed a burning smell. I was assured that this was because there was the flywheel was not molded properly and in time it would "fix itself".
Anyhow recently i noticed it was really hard to switch gears when the engine was running (mainly just putting it into first when the car was stationary). I figured the clutch cable needed some adjustment, but the mechanic said that my 89LX had an automatic clutch adjustment. I know you can pop the clutch up and it adjusts it to a small degree, but is there another way to adjust it?
Also I wanted to know if anyone has had the same experience as me where I bought a clutch cable from autozone. It was a brand named Pioneer. I bought one while ago and it cut about ten miles after driving. I had to put the stock one back in. I bought another one today thinking it was just that solitary cable, but it happened again!
