Hurst line lock install line help
As you can see by the pictures, I have hooked up the new HURST LINE LOCK, however, I must of hooked up the lines wrong or reversed them. When I flip the switch, press the brakes...Nothing. Please see if you can see by the photos if I did it wrong? Thanks
i helped once on one of these. IIRC you're supposed to run the front brake line(from the distribution block, not the MC, through the top hole of your hurst line lock control. then you run a new line out of the out hole of the hurst unit to a Male T block. one side goes to the left, other to the right and you're done for front line lock. all other holes should get blocked off.
Suspension / Body
AJE K-Member
Chromoly Upper/Lower Control arms
Welded in sub frame connectors
Energy suspension motor mounts
Energy transmission mounts
175 Coil Overs
Strang struts
Strange 10 way adjustable struts
Aluminum Caster camber plates
GT rear springs with a right rear air bag.
The steering is so sensitive when launching and going though the gears...Actually, I raced the car on Saturday and prob lost a 10th due to spinning so much. I also have a steering shaft knuckle rubbing against the header collector which I was able to radias the corners helped a bit. Is the shaft coming out of the fire wall sub post to have any play, side to side? I assume it does?
