WTF!! 89 mustang hunting idle at stop light it has a tune
Old 11-16-2009, 05:19 PM
grod297
grod297's Avatar
Originally Posted by AdderMk2
89 doesnt have a MAP sensor.. but good guess though. run your codes, and do a base idle relearn
This 89 has a map sensor... not a guess it is what it is. (original from ford)
grod297 is offline
Old 11-16-2009, 05:40 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no it doesn't, what your calling the map on an 89 , even though it looks like a map sensor is what is refered to as BAP sensor, it is used for barometric pressure change/ altitude change
mjr46 is offline
Old 11-16-2009, 06:26 PM
grod297
grod297's Avatar
Well since I am not a mechanic I will only state what I was sold. A MAP sensor for a 1989 MUstang from Auto ZONE part # SU208.
Looks like a duck quacks like a duck but if it is really a fish I am okay with it. The problem is the retarded idle.
But thanks for the correction .. I think.
grod297 is offline
Old 11-16-2009, 07:01 PM
AdderMk2
Banned
AdderMk2's Avatar
well, you didnt do something stupid like... connect a vac line to the BAP sensor... did you
AdderMk2 is offline
Old 11-16-2009, 07:53 PM
mjr46
mjr46's Avatar
I never trust autozone's listings, just trying to teach you the correct terminology and use of the part
mjr46 is offline
Old 11-16-2009, 10:34 PM
grod297
grod297's Avatar
Thank you I can use all the help
I can get
G
grod297 is offline
Old 11-17-2009, 05:46 AM
mjr46
mjr46's Avatar
just ask and we'll do our best to direct you to the solution
mjr46 is offline
Old 11-17-2009, 08:48 AM
streetstang88gt
streetstang88gt's Avatar
vaccum, maf, iac, plugs, cap and rotor, wires...i had alot of surges when my plugs had alot of build up..as well as one of my plug wires sitting on the header...could be a number of things...timing?
streetstang88gt is offline
Old 11-17-2009, 06:26 PM
lxman1
lxman1's Avatar
Yeah, you wouldn't want to do that!!
FYI, the map and bap are the same sensor. On speed density it is a map and on MAF it is a bap. When I converted mine over to MAF, I just removed the vacuum line and it became a bap.
lxman1 is offline
djbigskrilla
09-20-2022 01:04 AM
fdnyems19
08-13-2015 09:36 AM
stanngg
08-12-2015 03:43 PM
daytooday
08-11-2015 09:22 AM
UINZWAY
S197 Shelby Section
08-05-2015 10:34 PM
Quick Reply: WTF!! 89 mustang hunting idle at stop light it has a tune
