AOD T5 Crossmember Swap
I just swapped a guy my AOD for his T5. I gave him my AOD crossmember which had an exhaust hanger on it. The T5 crossmember I got from him did not have an exhaust hanger. I have an H-pipe setup with longtubes. The AOD setup used one side of the ehaust hanger. Do I need this hanger? Can the hanger be removed from the AOD crossmember and put on the T5 crossmember?
The exhaust hanger is a separate piece from the crossmember. The welds on the current crossmember can be ground down so each side can slide back and forth making it an adjustable mount. The bracket for the exhaust is not necessarily needed but it does help support the exhaust. I did not use one and alot of the times if you do it causes the midpipe to hang kind of low but that can be fixed by shortening the hangers that are on the midpipe itself and that can also vary by brand. The only one I have experience with that MAC H pipe and I know that would have hung really low. As long as you use the hangers in the back for the mufflers you should have plenty of support and not need to use the one on the crossmember.
