What to look for in late model Fox bodies
Old 07-18-2005, 03:56 PM
_Shifty_
_Shifty_'s Avatar
Default What to look for in late model Fox bodies
I'm currently shopping for a Mustang of this vintage*, and I was wondering if anyone had any tips on things I should be looking for to indicate if the car is worth buying?
I live in a snowy climate, where salt is used, so rust is obviously a big issue if the car was not winter stored. I'm not overly worreid about the engines condition, more about major problems that would be hard to fix.
* I may already have found one, an '88 hatch with newly rebuit engine and a body with some surface rust, but I haven't committed to it yet.
_Shifty_ is offline
Old 07-18-2005, 04:01 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: What to look for in late model Fox bodies
bondo.torque boxes..on a H/B look to see it the body has any deep rubs from the hatch.....floor pans,door pins,front end,any leaks,etc
vfast is offline
Old 07-18-2005, 04:24 PM
_Shifty_
_Shifty_'s Avatar
Thanks for the quick answer!
I've been carrying around a magnet with me to check wheel wells for bondo, but is there something else in those places you mentioned that I'm looking for, or just general condition?
By door pins, do you mean sagging doors?
_Shifty_ is offline
Old 07-18-2005, 04:42 PM
vfast
I ♥ Acer
vfast's Avatar
yes as well as the hatch..ask the owner has the 10 pin conection has been done as thier was a recall also the igintion has been recalled..make sure you do a carfax on anycar your going to buy.. you can also see if the recalls were done
vfast is offline
Old 07-18-2005, 04:43 PM
C/Note
I ♥ Acer
C/Note's Avatar
ORIGINAL: vfast
torque boxes
good answer....
C/Note is offline
Old 07-18-2005, 04:53 PM
vfast
I ♥ Acer
vfast's Avatar
I wouldn't buy even a bolt from NOS
vfast is offline
Old 07-18-2005, 05:04 PM
_Shifty_
_Shifty_'s Avatar
If the torque boxes are cracked, will it be obvious if I look at it without getting the car off the ground?
_Shifty_ is offline
Old 07-18-2005, 05:07 PM
C/Note
I ♥ Acer
C/Note's Avatar
ORIGINAL: vfast
i didnt know NOS sold bolts..?just kits and assys...? yeah shifty you can see bout you need a light also look at the top control arm bracket were its spot welded to the frame for cracks
C/Note is offline
Old 07-18-2005, 06:04 PM
vfast
I ♥ Acer
vfast's Avatar
I was talking about you
vfast is offline
copestang
10-11-2015 07:17 AM
mungodrums
10-07-2015 04:01 AM
dudeguy421
09-24-2015 11:16 AM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
Quick Reply: What to look for in late model Fox bodies
