Will this distributor work for a carb to efi setup?
Old 11-26-2009, 06:48 PM
RyaNCSU1
RyaNCSU1's Avatar
Default Will this distributor work for a carb to efi setup?
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
I already have an aftermarket msd coil, running at the end of my budget and dont want to purchase a costly distributor and controller right now. Looks like this one should be an easy setup.
RyaNCSU1 is offline
Old 11-26-2009, 08:13 PM
dragstang252
dragstang252's Avatar
that distributor is not going to work for a fuel injected setup. the fuel injected engines do not use vacuum advance like that is on the distributor. the f.i. engines computer advances timing based on engine parameters. fuel injected engine also have a control module on the distributor that runs the igniton coil.
dragstang252 is offline
Old 11-26-2009, 09:00 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you can purchase a reman one inexpensive at your local parts store
mjr46 is offline
Old 11-27-2009, 07:29 AM
RyaNCSU1
RyaNCSU1's Avatar
sorry meant to say for an efi to carb setup
RyaNCSU1 is offline
Old 11-27-2009, 08:20 AM
mjr46
mjr46's Avatar
as is, answer is still no....you need a dizzy with a steel gear on it for roller cam set ups
mjr46 is offline
Old 11-27-2009, 04:17 PM
lxman1
lxman1's Avatar
One designed for a 85 GT 5-speed will work.
lxman1 is offline
Old 11-27-2009, 04:51 PM
RyaNCSU1
RyaNCSU1's Avatar
^ then i dont have any way to trigger the ignition thought right?
RyaNCSU1 is offline
Old 11-27-2009, 05:58 PM
lxman1
lxman1's Avatar
The 85 Gt dizzy has the magnetic pick-up in it that should trigger the ignition. It triggers the Duraspark II box used in the 85 Mustang.
lxman1 is offline
67LimeCoupe
11-25-2015 08:55 PM
YoungStangsMan
09-05-2015 07:01 PM
raleigh05GTO
09-04-2015 07:09 AM
amandahchase
09-03-2015 10:09 AM
mtxplod
08-29-2015 01:43 AM
Quick Reply: Will this distributor work for a carb to efi setup?
