timing ????
Old 12-07-2009, 12:42 PM
1988TTOP
1988TTOP's Avatar
Default timing ????
i havent been on here in a long time and i am having a problem with the stang not having throttle response and if u get in the gas hard it will back fire though the carb i have rest the timing i dont know how many times hasn't done anything when u set the timing do u set it off the circle or the 90 on the top of the pointer
1988TTOP is offline
Old 12-07-2009, 12:50 PM
jkrum10238
jkrum10238's Avatar
i set mine of the pointer not the circle....idk for sure
jkrum10238 is offline
Old 12-07-2009, 01:17 PM
1988TTOP
1988TTOP's Avatar
thats what i thought but wanted to double check
1988TTOP is offline
Old 12-07-2009, 03:03 PM
zebo87
zebo87's Avatar
yeah set it to the pointer. also when was the last time you did a full tune up, cap, rotor, plugs, wires. could be time.
zebo87 is offline
Old 12-07-2009, 03:14 PM
1988TTOP
1988TTOP's Avatar
about 5 miles ago i have tried everything i can think of
1988TTOP is offline
Old 12-07-2009, 07:35 PM
lxman1
lxman1's Avatar
Try using a timing light. Much more accurate than a mark in the block.
You said carb, so I am thinking an accelerator pump problem. You need to see if both pumps are pushing fuel thru the discharge nozzles when opening the throttle.
lxman1 is offline
Old 12-07-2009, 08:29 PM
1988TTOP
1988TTOP's Avatar
fuel is comein out of both i am thinkin bout tryin a smaller carb
1988TTOP is offline
Old 12-08-2009, 05:13 PM
1988TTOP
1988TTOP's Avatar
bump.....
1988TTOP is offline
Old 12-08-2009, 06:59 PM
90notch_5.0
90notch_5.0's Avatar
+1^
I have a 750dp and works good (mechanical secondary). I'am almost sure something is wrong with your carb.
90notch_5.0 is offline
Old 12-08-2009, 07:23 PM
1988TTOP
1988TTOP's Avatar
i have been using a timing light and like i said i have fuel coming out of discharge nozzles
1988TTOP is offline
Quick Reply: timing ????
