Gear for speedometer
I called Ford and they said I need to tell them what color and how many teeth are on the gear that is in my car. I have a 88 GT so can anyone tell me what color it is and how many teeth are on it before I rip apart my dash?
It's not in the dash, it's on the end of the speedo cable that goes into the transmission.
Depends on if it is AOD or T-5 manual trans and what gear in the rearend.
If all stock, then remobe the retaining bolt and pull the cable assembly from the trans and look at the gear. It is just held on to the cable by a clip.
from steeda.com
Manual Transmissions with 7 Tooth Drive Gear
* 1983-1989 T-5 OEM
* Pre 1993 T-5 Aftermarket
* 1996-1998 Cobra T-45 OEM
* All Tremec Transmissions
Manual Transmissions with 8 Tooth Drive Gear
* 1990-1995 T-5 OEM
* 1996-1998 T-45 OEM Except Cobra
Automatic Transmissions with 7 Tooth Drive Gear
* 1983-1989 Automatic Transmissions
Automatic Transmissions with 8 Tooth Drive Gear
* 1990-1998 Automatic Transmissions
* 1983-1989 T-5 OEM
* 1990-1995 T-5 OEM
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
