Problem with brand new Spec 2 clutch
Old 12-09-2009, 06:30 PM
RyaNCSU1
RyaNCSU1's Avatar
Default Problem with brand new Spec 2 clutch
Installed it as I was redoing the top end of the engine. Still working out the kinks in the engine but took it out for a test drive today and noticed too things.
1.) Clutch is much softer than it was when i first installed it all of 10 miles ago.
2.) Hearing a light squeeling noise when the clutch is engaged. Goes away with the slightest pedal pressure. Sounds like a bad TOB, used the spec one. Grrrrr.
3.) Also noticed random bits of smoke that seem to come from the bellhousing. The volume of smoke makes me think clutch but I dont smell clutch.
Anyone else had these kind of problems?
RyaNCSU1 is offline
Old 12-09-2009, 07:18 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
could be the TOB getting ready to go SNAFU
mjr46 is offline
Old 12-10-2009, 07:58 AM
AdderMk2
Banned
AdderMk2's Avatar
the smoke is normal, its the kevlar burnishing
the clutch being softer is normal, the pressure plate is breaking in
my spec TOB squealed too, so I replaced it
AdderMk2 is offline
Old 12-11-2009, 11:19 AM
RyaNCSU1
RyaNCSU1's Avatar
^Any chance of a catastrophic failure if I just let it ride for a while? Obviously in no hurry to take the tranny back out.
RyaNCSU1 is offline
Old 12-11-2009, 05:16 PM
AdderMk2
Banned
AdderMk2's Avatar
sure is... the bearing can seize up and start spinning, which can either cause the clutch fork to be destroyed, or even take out the fingers on the pressure plate
AdderMk2 is offline
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
5.0 kevo
09-03-2015 06:24 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Problem with brand new Spec 2 clutch
