Rear end
RE: Rear end
I called a gear place close to my house called Oceanside driveline. They said if they rebuilt the rear end and but 3:73 gears in it, it would be about 850, thats including everything. Does that sound about right?
RE: Rear end
thats right on if they mean doing a master install. which is all the bearing all the way to the axle bearings and seals. i would find out how much labor is and how much they are charging you for parts.
RE: Rear end
ORIGINAL: seanjohncombs001
findout exactly why its that high
RE: Rear end
My though was about $450 labor, then $180 gears, $90 install kit, $50 tracloc rebuild kit. i know the labor sounds high, but take into consideration the extra for the trac loc rebuild, and the extra for the master install.
RE: Rear end
Do you think this is a urgent problem or it can wait a while?
RE: Rear end
I was planning on getting in done in 2-3 weeks or a month at most, im guessing it will be fine till then, cause ive had the car a little over a month, and it didnt even start doing it till about 2 weeks ago.
Dragonus18
09-09-2015 01:21 AM
