Noise in 1994 gt interior
first off i would like to say i have a mostly stock 1994 mustang GT that i just got back from the shop a few days ago. also i know some about fixing cars but i don't know much. i just had the PCV screen and the radiator along with some vacuum hoses replaced. And when i first drove it again there is this beeping noise coming from the dash board but unsure where my guess is that is coming from my radio. but my other guess was that it was coming from the old cd player that was left in and my mechanic could have fixed something that was broken and it fixed the other cd player from the original system and that is causing it to beep but that is just my guess. all i can really tell you about the beep is that is just comes on when it wants to and some will beep for along time and sometimes it will only beep once or twice. so any help on this problem would be helpful.
also after having most of my cooling system replaced on about 12/13/09 my car is still overheating the only thing that has not been replaced in the last 3 months is the water pump and that is about 1 year old so my question is what else could be causing my car to heat up. also its not that it is overheating but it is going up to about the A in normal in the temp gauge. any info on this would be help full as well.
the last thing that is going on with my car is that i am having high oil pressure is that good or bad?
any info on any of these problem would be greatly appreciated.
(if this is in the wrong section sorry and feel free to move it.)
thanks Patrick
thanks Patrick
has your car ever been in an accident? many fox owners report a beeping coming from the dash when the airbag module or parts of the air bag system fail.
also, unless you are testing the temp of the cooling system with a REAL gauge.. like a non contact laser thermometer.. or a mechanical autometer gauge... you shouldnt worry too much about what the stock, ever so innaccurate, gauge reads
i am not sure if the airbags went off but i think the trunk has been replaced because the panels say replacements. but i am not sure i have not done a carfax on the car yet. so should i just look to buy new airbags for the car?
no. airbags are quite possibly the most expensive part to replace, short of a reman motor or tranny. if you're that concerned about it, get a diag at a dealer.
like Adder said, that same beeping can be heard in the Fox models near the radio, and it's the airbag diag module. I'm unsure if this even exists in the SN models, but taking your radio out will confirm its presence and location. Its a blue box, about the size of an aftermarket radio.
KingRando
10-02-2015 08:06 AM
