Vibrations in trany
Vibrations in trany
So i have a 1989 5.0 i have replaced the rear main seal, put ultra light flywheel on stage 3 zoom clutch, New T-5 it is only a month and a half old and i Ballanced the Drive shaft i have BAD BAD BAD vibrations when deccelerating from 4th gear at 2k rpm 1-2-3 good but reaching high way speeds is out of the question please any help would be awesome.
ummm
ok i have checked the dif and the slip yoke the drive shaft has very little play i would say not more then an 8th of and inch i have yet to balance the tires that will be the next thing i do as soon as the shops open up the fly wheel was bought specifically for my car along with the stage 3 zoom clutch more to follow ohh but i did see what would happen if i went to higher speeds going arround 95-120 in 4th gear arround 3k-4,500rpms it runs nice and smooth but when i clutch in the car Vibrates horibly
I didn't ask if the flywheel was specifically bought for your car...........alot of the time the aluminum and ultra light flywheels come with a 50 oz weight and 28 oz weight, my flywheel was specifically bought for my car too and it came with both weights...see my point??
ok so i talked to a mustang tech. today and i think i found my problem i have an automatic slipe yoke on my driveshaft that has a balance weight on it remove the balance weight and put the manual one on it and that should fix the problem **** FORD dealerships they sent me a F-150 slip yoke and told me that was the one picture in rout more to follow on the job.
ccdguy
09-19-2015 05:20 PM
