I'm thinking I'll go the Moser 31 spline axles and get my rear end clutches. Think I should replace the gear oil with rp gear oil or normal gear oil with friction modifier?
if you get 31 spline axles your going to need a new trac lock because stock is 28 so that clutch rebuild kit isnt necessary....unless you buy a used/worn out 31 spline trac lock
