88 5.0 header bolts
The factory headers are severely crimped to allow the larger headed bolts to be used. Aftermarket headers are not thus the large headed OEM bolts will not fit. I have never had a header bolt problem with the standard header bolts. I installed my MAC nickel plated shorties back around 1990 and used the supplied paper type gaskets. I have never had to replace those gaskets. The bolts loosened up during the first few heat cycles as they all do, but I have never had them come lose since. I'll see how they do when I swap out engines soon and I finally have to use new gaskets.
can somebody please tell me what the factory length headers bolts are? im getting ready to replace my crappy paper gaskets on my aftermarket headers, and wanting to go with a bolt with a 3/8" head on it. makes it much easier to tighten down but just unsure of length. thanks
so like the percy gaskets, can the stage 8 bolts your talking about be used more than once? i ask because i know in the next 12 months i will be taking the turbo route but until then, im just freakin tired or hearing the crappy leak i have, and i also know im going to need a good gasket and bolt for the turbo manifolds so what better than to be able to re-use what i already have.....
i found some percys locking header bolts on ebay for $59.99. had the same concept sounds like being able to tighten them with allen wrenches. what do you guys think? any different?
maestro1024
09-21-2015 02:40 PM
trashxtrash
09-20-2015 10:49 PM
