HEY,do i have gears?
As some of u know i just got my stang,so im kinda new to this s**t.well heres the deal my car at 70 mph is at like 2500 rpms in 5th.Do u think the guy before me put gears in her or does she do that stock?????I would appreciate all your help.....chris</P>
Originally Posted by 94gtchris
also above eighty five mph my car shakes violently why would it do such a thing?any help would me much appreciated.
wheels not balanced
tranny not aligned properly with the rear end.
ds is out of balance.
some wrong in rear end. may be there is gears installed wrong
As some of u know i just got my stang,so im kinda new to this s**t.well heres the deal my car at 70 mph is at like 2500 rpms in 5th.Do u think the guy before me put gears in her or does she do that stock?????I would appreciate all your help.....chris</p>
this is a close way of telling. on a 273 car you should be a little lower. you might have 355s or you jsut pull the cover and cut the teeth.
I'd say 3:73's if it real close to 2500rpm or 3:55's if it slighty lower, say around 2300-2400. I run around 2000rpm @ ~75mph w/ stock 3:08's. </P>
As far as the shake, start w/ wheels & tires (balancing/condition/alignment),then check for worn suspension components. </P>
well here's another idea for you to check and see what gears you have....pull the speedometer gear out of the tranny and check the color and inspect the teeth on it....ford color codes speedometer gears for the appropriate gear ratios that you want...mine has 4:10's in it i forget what color speedo gear mine has its been awhile since i installed them...however, its only going to help you if the last dude had enough of a brain to change the speedo gear when upgrading the gears....if you pull it out and it looks like its chewed to shreds, obviously not...hope this helps, luv jenna
Originally Posted by 95cobragirl
well here's another idea for you to check and see what gears you have....pull the speedometer gear out of the tranny and check the color and inspect the teeth on it....ford color codes speedometer gears for the appropriate gear ratios that you want... mine has 4:10's in it i forget what color speedo gear mine has its been awhile since i installed them...however, its only going to help you if the last dude had enough of a brain to change the speedo gear when upgrading the gears....if you pull it out and it looks like its chewed to shreds, obviously not...hope this helps, luv jenna
teal
i went to f**kin midas today and they said that it was gonna cost 510buckaroos fornew rear rotors and calipers plusinstallationso i guess i gotta get off my lazy *** and fix it myself,doesn't that suck! bye the way......jenna is hott<IMG src=smileys/smiley17.gif border="0">
