Car smokes badly and plugs are black. where to start?
60lb injectors are just what i had on the bigger motor and when they tuned this one they said those wouldn't be a problem, i only run 12lbs of boost with 11degrees of timing to keep it safe. They said at 500hp it can crack a stock block. Its at 476hp with a real safe tune, but when it is in neutral and u rev it up it bust up pretty bad the plugs smell like fuel and are wet with oil the smoke is a grey color. I'm goin to do a compression test tonight but i was tryin to get some ideas on things to try and to look at. I haven't ever had any problems with it so i dont really know where to start.
Well "MJR46" i dont know what you are i guess somekind of admin but when your aggrevated and you post somethin on here to get help and someone post a smart alec commit i'm not goin to be polite b/c it is appearent that he has no intentions to help in the first place, so if you have no intentions on helping why post something? Therefore i really dont care about your warning. I do however appreciate the ideas unfortunately it hasn't turned out to be something that easy. "pro50sc" I appreciate the help 2 of the cylinders have very little compression so i'll just put one of my other bottom ends in it thanks though
G/l man, I hope you get it worked out. Do you know what the lack of compression is from? Or have you not gotten that far yet?
Two wrongs don't make a right nor your justification for an outburst, if you have an issue with a member notify me and I will take care of the situation swiftly and fairly....otherwise, Get over it , it's the internet, don't take things so personal, and if you don't care for my warning then your more than welcome to seek help elsewhere...good day
"MJR46" Shut the hell up and go somewhere else ur a ****in dumbass. I dont give a **** what u or ur butt buddies say. If you can kick me off then do it, otherwise shut the hell up. i'll just have to make another email and register again. There are some people that want to actually help so quit taking up space on my thread u jackass, and tell ur mom i'm sorry i couldn't stay for breakfast.
lol wow.... anyways your going to replace your whole bottom end before finding the problem????? Are you made of money?
anyways this thread is done. OP you need to take a chill pill.
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
