Car smokes badly and plugs are black. where to start?
Its a 302EFI, R-Trim, Twisted Wedge heads, 60lb injector, Pro M mass air, I was getting on it and shifted into second it fell real sluggish all of a sudden, it wouldn't turn up then it shut off. When you crank it it idles poorly and smokes badly i cant tell if its fuel or oil but all cylinders are gettin hot, the plugs are covered in oil, i checked the pcv it wasn't clogged and made sure the mass air was connected, and swapped distributors but still no progress any suggestions. thanks eric
thats a hell of a lot of motor to not know where to start when the plugs are wet with oil....
its really not a whole lot of motor, it is a stock 94 hypeteutectic bottom end and i haven't ever had a single problem with it, so keep ur stupid ass commits to urself i'm tryin to get some help on something that is frustrating me and bein a jackass doesn't help
Originally Posted by slick81cj5
(Post 6719653)
ohh man i wish i could be cool enough to be a member of 6th gear, why dont yall get ur dicks out of each others mouths and go post ur stuff somewhere else
(Post 6719609)
Wow, i hope your **** blows up douche. How do you expect to get help while you call out everyone who posts in your thread? Chill the fvck out and show some respect.
OK everyone chill out. The guy asked for help, not for a flaming. Help the guy or STFU. It's not like he asked how to change his oil.
60lb injectors are just what i had on the bigger motor and when they tuned this one they said those wouldn't be a problem, i only run 12lbs of boost with 11degrees of timing to keep it safe. They said at 500hp it can crack a stock block. Its at 476hp with a real safe tune, but when it is in neutral and u rev it up it bust up pretty bad the plugs smell like fuel and are wet with oil the smoke is a grey color. I'm goin to do a compression test tonight but i was tryin to get some ideas on things to try and to look at. I haven't ever had any problems with it so i dont really know where to start.
Originally Posted by PRO50SC
(Post 6720379)
