3G upgrade on a 83 capri
im not familiar with capris but i can say that the "kit" i bought for my install basically was designed so you could put the 3g alt into any car. it was just a plug/harness that hooked into the startor connector and the other 3 or 4 pin connector, cant remember, and that was connected to a 12v switched source. then you just had to run a wire from the battery to the terminal on the back of the alt.
basically made the 3g a 2 wire hook up
I already have the 3g alt and plug for it. I was just wondering how to use the factory reg harness to hook onto the 3g harness.
This is what I have figured out.
4AWG from B+ post on alt to Batt + side of solinoid.
"A" from reg to "A" on 3G
"S" & "F" wires from reg to "I" on 3G
Stator wire on on 3G to "S" on 3G
The 3 wires on the reg are A,S,F and on the 3G are A,S,I...
Is this correct??
Is this correct??
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
