if the ignition switch wire is bad then it would not even crank right??? cause i can get it to crank just just fine sometimes and other times very slow and then just a click
theres a lot of resistance somewhere. how long has it been since you have changed or even looked at the battery cables? what do the battery cable ends look like?
the thing that gets me is that it only dose it sometimes not all the time i would put my life on it that i could go out to the garage and it would start and run great
is it still the same starter?how good is the solenoid grounded to the car?
yea i took the starter out and had it tested tested good so i put it back in the starter solenoid seems like it is ground good its tight and everything is clean behind it
