New alternator for electric fa
I recently bought a 91' GT and was asking a mechanic about installing an electric fan on it. he replied by saying the clutch fan was actually better and that if i still wanted to do the conversion i would need to buy a bigger alternator. is that true, or can the stock alternator handle it? i had a 280zx turbo before thiscar and did the conversion along with an ignition amplifier and coil on the stock alternator and itworked fine...???
depense on how big the one is you need something in the 2000cfm's I would put a 140-160 amp in it with an underdrive pulley..this will about double the life of the alt and pick up a few ponies and still be big enough to run the fan and a nice size amp.it's a win/win thing<edited><editID>vfast</editID><editDate>37945.7302430556</editDate></edited>
Well, I defenetely aggree that electric fans are a great idea for cooling engines, i know ive had about 5 total 5.0 engines, trucks, thunderbirds, cougars, 5.0 mustangs, and they always have cooling problems someway some how, but what my friends did was get a underdrive pulley so you would get more amps on your alternator and with the water pumps will flow better, with more amps get a small honda fan or toyota and wire it up with a current reflector so that you can adjust the speed or power intake of the fan, this should kool the radiator a lot, me and my friend did it and his car has no problems at all, he has gained a lot more miles / per gallon on high way use and it was a 6 hours project , well 7 hours, we did go to eat at jack in the box, but anyways, yeah its a good project to do with friends drinking beer and just having a good time, with a sour dough jack and a beer, and a good working mustang, we went of to the strip clubs for a night to us, well, i digress, good luck and hope it helps</P>
You can put a smaller pulley on the alternator itself and it'll spin faster. Since it's a smaller pulley some people mistakenly think of it as an underdrive pulley, but really you're overdriving it. Stock motor you're probably ok, but if you rev up to 7k or whatever you might fry it. A matched overdrive alternator pulley with an underdrive crank pulley will 0 out the effects on the alternator and it'll be like stock (but less mass to turn usually).
Believe me, if you do any driving at night, or commute, with the electric fan you need a larger alternator. I installed pulleys and an electric fan, and it doesn't work off the stock alternator. After two batteries and finally blowing up the diodes in the alternator, I switched to a 140amp powermaster 1 wire alternator and have had no further problems. On a rainy night in commuter traffic, with the defroster, fan, lights and wipers going, you'll be glad that you did.
