Rear end
Rear end
ok so My car is making a vibrating noise, and its coming from the rear. It only happens at higher speeds 30+ 40+. It also is not there when i am on the gas, but as soon as i take my foot off the gas is comes back.
What do you guys think it could be?
I had a similar situation in my car when I put in a rear end that I bought from a MF member... It was the crush sleeve/bearings on the pinion. I had to reinstall the gears and carrier and the problem was fixed.
Thanks guys. I figured out what it was. My drive shaft was being held on to my rearend by 2 bolts. And they were finger loose to take off. I went out and bought 2 more bolts, tightened everything back up , and now the noise is gone.
Dragonus18
09-09-2015 01:21 AM
