car wont start up
car wont start up
ok i went to start up my stang when all of a sudden it wont start... the only thing i could hear was my fuel pump.. i turn the key all the way and nothing else happened... what could it be.. no gas maybe?
RE: car wont start up
oh no it turns all the way over, thats when the check oil light goes on and the check engine.. but the oil is fine.. how could it be the engine.. or could it be sumthin else.. like the battery..
sounds like the starter is shot IMO i would upgrade to a high torque mini starter so you will have plenty of cracking power. The mini starter hav ea lot more cranking power and they use a lot less power to run them and they dont get the common problem of heat soaking either.
first u could start off simple and check ur plugs. check the plugs to see if they are covered with gas or see if they are black.or just change them for the hell of it. then check ur battery try to jump it. if u say its turning over fully then i dont really thing its ur battery but i could be wrong. if that doesn't work try a new starter and the last thing i would do is think about maybe having a head gasket blown. if it was blown it could turn over but wont start up b/c it has no compression. cant say exactly what it is but just try a few things u'll find something out. also check and see if any fluids are coming out your exhaust. if so that = not good. if it is your collant coming out ur exhaust then its a head gasket. and just another thing to throw in there could the engine be flooded? give it a couple of days maybe that was it.
i dont understand how this can happen overnight.. everything was fine... i mean if my headlights still turn on.. then it obviously cant be the battery... so u really think its the starter then?
