SPEEDO STAYS AT ZERO (89 coupe)
got a 1989 5.0 coupe 5-speed...but the speedo stays at zero. should i look into the cable being broken? or any other causes?? any advice is greatly appreciated...
1.) Underhood check for melted wires.
2.) Is it connected to the trans?
3.) If it is connected, take it off and check the plastic gear for wear.
4.) If everything's fine, then your speedo might not be connected to the back of your instrument cluster?
Mattdel is right, and even if the speedo gear is not fully worn out, it can make your needle bounce and jump around.
Matt's 95 Stang
10-05-2015 07:16 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
DreadPirateRoberts
09-26-2015 02:11 PM
09-17-2015 07:32 PM
