New BBK intake
what do you guys think of the new BBK intake system i think it is a good peice but not sure of the performance gains...any help
RE: New BBK intake
it's gives a different look but for the $$$ thier is alot better options
RE: New BBK intake
what is a good intake for the money then don't forget i have speed density still
RE: New BBK intake
5.0 Mustang did a dyno test on a few intakes.
The bbk, edlebrock, gt-40, stocker. You might find the article on their website. www.50mustangandsuperfords.com Off the top of my head, I believe the GT-40 did the best. They ran AFR 65 heads, long tube headers, a mild cam, and a speed density system, by FAST technologies. All on a 302 block btw, the GT-40 intake is different from the Cobra intake. |
RE: New BBK intake
it says on the web site that the dyno showed a 28hp increase but it doesnt say what all they had done to the car in conjunction with intake i mean ill buy it if its a 28hp increase just by bolting it on
RE: New BBK intake
its not going to give you 28HP, you should start with a 87+ throttle body which is 60mm compared to your 58mm. the only bolt on part that might give you that much is a set of heads, and with the stock air induction most of them wont.
RE: New BBK intake
professional products make a good intake and can get it polished for around 325.00,then used a 65mm t/b
RE: New BBK intake
yeah ive already got a 65mm tb and fenderwell cold air intake
RE: New BBK intake
if you got lots of money go with the edelbrock performer rpm 2,
but if you got a small budjet like the rest of us go with the professional products intake, its the same as the rpm1, but you have to clean up the ports a little. these are some prices I checked out be4 I bought my pp intake. prices in canadian dollars. gt-40 from ford $775 edelbrock performer2 $790 professional products $400 so you can buy more stuff with the extra couple hundred bucks. |
RE: New BBK intake
thanks for all the responses!!!!
