Stock Injectors
RE: Stock Injectors
ORIGINAL: sastangman
the stock injectors are 19lbs dont get 24lbs without getting
a good set up heads,intake and headers
RE: Stock Injectors
yeah, you could always put some #24s on, but then you would have to bring the pressure down, and get a new maf for the new inj. i wouldnt swap them if it were mine though. #19 are good for under 300HP depending on the setup could be less, but until you do heads, cam, and intake, i wouldnt worry about it. or if you plan on running NOS it would be better.
RE: Stock Injectors
If you reduce the pressure below the specified amount for the injectors you reduce the accuracy - if you have a MAF calibrated for 24lb injectors the ECU will pulse X amount but you'll squirt less fuel and it won't get properly atomized. Run your injectors at the proper pressure, get a MAF for the injectors, you'll be ok. 19lb injectors are perfectly fine for stock-ish applications.
09-16-2015 07:53 PM
