1994 Cobra window help.
My driver side window just recently started to act up. When i roll it doen it wont go down all the way. I can hear the window motor moving, but the window isnt. same thing when i roll it up. It needs help to roll to the top then when it gets there the window motor wont stop. What could be wrong? What is the best way for removing the door panel?
the are three plastic rollers inside the window motor they are packed in greaser you need to remove the motor clean out all the broken plastic and grease and add the new rollers and grease....
to remove the door panel use a trim tool to pop the plastic retainers loose and unbolt the handle and switches etc |
Hmm that doesn't sound good. I'm in the army and since I'm only a Private First Class, I don't have a house or garage of my own. I had to leave all my tools 1400 miles away. Thank you for the suggestion; it does sound like something is stripped in there. I think I'm going to have to take it to the dealer. :/
