water pump/timing cover - MustangForums.com
Old 02-21-2010, 01:47 PM
lx5.0
lx5.0's Avatar
Default water pump/timing cover
i removed my timing cover to replace my front main seal and well i had pulled the water pump also when i put it back on do the gaskets take silicone or do i just put them back on dry
lx5.0 is offline
Old 02-21-2010, 02:20 PM
BlessedHellride
put them back dry, all except the small pieces for the oil pan. Use a small amount of RTV where the gasket joins together to the old gaskets seal on the timing cover.
BlessedHellride is offline
Old 02-21-2010, 03:08 PM
primetime5.0
i put silicone on all of them, seen it a few times where the water pump leaks because it has no silicone on it
primetime5.0 is offline
Old 02-21-2010, 03:34 PM
88BlueGT
Silicone it..... why wouldn't you.
88BlueGT is offline
Old 02-21-2010, 06:13 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by BlessedHellride View Post
put them back dry, .
maybe in a perfect world when all was new and the surfaces new were true, on older ones and parts that have gone through numerous heat cycles and been subjected to the electolisis/corroding affects of coolant causing pitting, I'd never suggest putting them back on dry........a small layer of "the right stuff" by Permatex will insure all imperfections are sealed up
mjr46 is offline
Old 02-21-2010, 06:55 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Why in the hell would you pull the timing cover to replace the front seal?
PRO50SC is offline
HRnB
Off Topic
40
09-02-2018 02:57 PM
jerrytubes
10-23-2015 01:11 PM
winner99
Want To Buy Ads
10-01-2015 02:06 PM
Boostaddict
Lethal Performance
10-01-2015 09:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 09:57 AM
Quick Reply: water pump/timing cover
Featured Sponsors
