head gasket???
head gasket???
I have an 89 5.0 lx coupe and I keep losing water in the radiator. Now I keep looking in the oil and there is a small amount of foam in the tank sometimes it doesnt leak ANY coolant and I have NO smoke coming out of the tailpipes so, I guess being out of 5.0's for awhile now, is this a head gasket? I'm gonna drive it till she blows cause I love my 5.0's
RE: head gasket???
Sounds like it. If you're losing coolant, it's either a leak in the cooling system or an internal leak into the engine. My first thing to do would be a cheap fix try...get a bottle of that stuff that seals small cracks in gaskets (for cooling system). If the leak is small enough, this could fix it and you'll be fine. If that doesn't work, go for a leak-pressure test, that'll confirm or deny a head gasket problem.
