429 conversion
RE: 429 conversion
10 years ago i had a 1982 mustang..it was a 302 car..but i put a 429 in it..you need a truck oil pan..and special headers..oil pump and screen and pick up ..there is several companys that make a complet kit for around 800-1000$$..includes headers oil pan ..mounts or front plate and 2 inch headers...i never had mine at the track ..but with a mild 429 ..it was killer to drive..it woulkd probaly ru8n 11:50-12.00 ..
RE: 429 conversion
IMHO not worth it. if i only got a mid 11 out of it i would be highly dissapointed knowing a 302 can run that fast. also with a BBF you gain alot more mass up front. you want your car as light as possible when racing
RE: 429 conversion
I like the idea but you do know you will definitely need to upgrade the tranny and rear end too! also need much bigger brakes and springs up front due to the extra weight unless you plan on using an aluminum block. a 460 swap might be much more practical and parts would be easier and cheaper to find.
RE: 429 conversion
Yea...but a supercharger on a mustang is about as common as a fart can on a honda. I say if you got the time and resources go for it. With a good HCI combo, that thing would be sick...not to mention the sound...
RSRXION
05-10-2006 02:07 AM
