i have a 1988 5.0 i turn my heat on and its blowing but just air any ideas... the lines under the hood are all hooked up it looks normal there.
you mean it's blowing air but not heated air correct?? cause if you reread your statement that is incorrectly worded.........anyway, enough of the grammer lesson, is the blend door cable when you turn the dial feel operational?? also check lines under hood going into heater core, are both lines warm/hot or one hot the other cool??
sorry for the grammar issues... yes the blower is working but not blowing hot air. the controls are working properly when switching to defrost, floor and vents. i will have to wait to see if one line is cooler then the other i am at work.... and ill recheck the vacuum lines.... but were is the blend door cable and what does it look like thanks for the help..
