intake spacer
RE: intake spacer
for my setup i went with the 1' but for some reason you cant hardly tell on my motor that the intake sits the much higher. um.... must be the tall valve covers
yea it does help some by rasing the power band up a few rpms. larger spacer the higher it moves it up some. you got gear and with was described i would rock a 1' this will also help you out if you get tall valve covers
RE: intake spacer
I got pushrods when i ordered the heads. I figured I might as well. I'm pretty sure I got the clearance. I guess i could put something on top of my hood and set it down and see if it clears, but I think I should be ok.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
