idles up and down
Old 03-10-2010, 04:05 PM
nick_simmons59
nick_simmons59's Avatar
Default idles up and down
i just bought a 94 mustang gt 5.0 and it sat over the winter outside.
the problem is that when im idling the car will go up to like 1500 rpm's and then back down to 900-1000 and if it sits running to long it will stall. i was thinking that it is probibally bad gas and needs some sea foam or it might need a new sensor switch for the throttlebody. idk i dont know alot about this car yet because i only bought it 4 days ago. i do know that it has 30 pound racing injectors and 3:73 gears.
nick_simmons59 is offline
Old 03-10-2010, 09:57 PM
raftdaddy
raftdaddy's Avatar
try adjusting the liitle screw that adjusts the throttle body blade.you'll see it on the back just above the throttle linkage.open it up a little and see what it does.if it closes to far it opens,then closes and so on,hence roaming idle.i just went through this,so if it not that somebody else can step in.
raftdaddy is offline
Old 03-11-2010, 12:30 PM
94ford5liter
94ford5liter's Avatar
also check your idle air control, it is on the side of the throttle body. With higher mileage cars, it can get very dirty and create the problem you are describing. You can try cleaning it with MAF cleaner or throttle body cleaner, but you may have to replace it. Just try cleaning it first.
94ford5liter is offline
Old 03-11-2010, 02:47 PM
1ATony
Former Sponsor
1ATony's Avatar
Allot of times the IAC is the culprit.
1ATony is offline
Old 03-12-2010, 01:47 PM
nick_simmons59
thanks i havent cleaned it yet but i was inspecting the car and the whole system was broken it didnt even clip on. i think im getting some k & n air filters instead of the stock ones
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Quick Reply: idles up and down
