roller rocker help needed
Old 03-13-2010, 11:37 PM
nacanitihs
nacanitihs's Avatar
Default roller rocker help needed
ok so i am trying to install my 1.6 pedestal roller rockers and i need some assistance.
now i am supposed to set the intake when it is closed and the exhaust open and vice versa correct? and when tightened to 18 ftlbs i should be able to slightly spin the roller but not jiggle the rocker? or does anyone know the gap that should be between the roller and the valve when the valve is closed? i have a bunch of shims but i was told its not a complete set and i am not sure of what sizes they are. ive just been kinda stacking them until they dont compress the spring.
also one of my lifters is squishy. i can push the push rod a little in. does this mean i need to replace the lifter or is it just not filled with oil?
here is a vid of what im talking about
thanx a lot
nacanitihs is offline
Old 03-14-2010, 03:36 AM
toms93lx
toms93lx's Avatar
are they adjustible rockers? if not set to torch......i have a 93 and the stock setting is 18 to 25.....shoot for 20 ......rool the motor over a few time after you torque it then make sure the torque is the same
toms93lx is offline
Old 03-14-2010, 03:38 AM
toms93lx
toms93lx's Avatar
if they are adjustible just call ford or sumitt and ask them what the spacing is
toms93lx is offline
Old 03-14-2010, 06:48 AM
AdderMk2
Banned
AdderMk2's Avatar
*sigh* Hydraulic roller systems dont use lash....
Justin, if you still have my number, call me up later on today.
But its Exhaust, when the intake begins to close, and Intake when the exhaust begins to open
Adjust to zero lash, then 1/2 to 7/8 turn more, to attain torque
Have you already checked for proper valvetrain geometry with a pushrod length checker and solid lifter?
AdderMk2 is offline
Old 03-14-2010, 10:59 AM
raftdaddy
raftdaddy's Avatar
my 1.7's said:
both pushrods equal length,lowest they can be
torque 18-20
if under 1/4 turn to torque,push rod too long
if over one turn,shim.small shims are 1/2 turn,big shim 1 turn.
thats it. some say to torque 24 ft lbs but i don't think it matters.there is so little adjustment.just make sure you blow all the oil out of the holes before you torque. my 6.25 push rods were bang on.
raftdaddy is offline
Old 03-14-2010, 10:13 PM
nacanitihs
nacanitihs's Avatar
i have not checked for proper pushrod length but the stock ones worked just fine with the normal rocker arms on the gt40x heads.. they seemed to bolt up pretty well.
ok so when i set them to 0 lash (no gap between roller and valve) i then turn it about 1/2 of a rotation and it should be at proper torque? so the valve spring will compress a little?
and i dont think i have your number in my new phone..
Old 03-14-2010, 10:38 PM
raftdaddy
raftdaddy's Avatar
0 lash then as long it torques between 1/4 and 1 turn your good.
Old 03-15-2010, 11:23 AM
nacanitihs
nacanitihs's Avatar
anyone have any idea about that squishy lifter i posted that vid about?
Old 03-15-2010, 09:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
HOW 'BOUT PRIME THE OIL SYSTEM THEN SEE IF IT IS SQUISHY??...lifters bleed hydraulic pressure off, so prime and recheck
mjr46 is offline
Old 03-15-2010, 10:36 PM
nacanitihs
nacanitihs's Avatar
ya was def cuz there was no oil in them lol. i got it all buttoned up today and running well. i had to clearance the inside of the valve cover in a few spots but was no big deal.
now all i gotta do is finish installing the nitrous kit... , cut the holes in my hood out and mount up the drag radials to my extra wheels.
thanx everyone for your help!!
djbigskrilla
09-20-2022 01:04 AM
MusicCity615
09-27-2015 12:53 AM
Tyoung68
08-25-2015 04:31 AM
WDScott
08-17-2015 06:38 AM
defarmer
08-13-2015 06:40 AM
Quick Reply: roller rocker help needed
