I have a88 5.0 with factory alternator.. To move my battery to the trunk what Alt. wire do I need to bring back to the on off switch and from were under the hood and how. Do I splice into some wire or just cut it and bring it back Thank you so much for your help I have not been able to find this info anywere for the factory alt.
That is the proper way to do a battery relocate. As said you should do a 3G upgrade as well. The wire you see going to the kill switch and up to the front solenoid is the one that gives power to the car's ignition, fuel pump, acc.... Do it this way......
Im still wiring mine up. So do you run the alt cable to the terminal of the kill switch that has the power cable coming from the battery or the one that is going to the solenoid?
