Question about fox bodied mustangs/GT (87-93)
RE: Question about fox bodied mustangs/GT (87-93)
yes but the suspension is the same
ORIGINAL: vfast
there is handling difference between them the LX has a slighty lower coeffiection due to the wing and not have the front air damn
its not called power traction. its called traction lok. its ford's name for it. seems like you a made up wording there
ORIGINAL: black89gt
dude you dont know what power traction is? hahhahahhaha it is limited slip basically
first off its QUIK not quick.
second LX had traction LOK unless its a 4 banger conversion or the clutches inside are worn out. they didnt put a single wheel in the 5.0 8.8 rears. they came with traction lok from the factory now if youre doint burnouts alot it will wear the clutches fast and cause you to have single peel.
ORIGINAL: black89gt
also i see alot of lx's doing burn outs on the street and only one tire spins, and i asked them if they had traction lok as you said Quick and they said " NO"
So to pick this up, it's a difference of rear sway bar, different bumper, side cladding and a spoiler?
How tough is it to get the GT appearance for an LX? Cost, source? I am shopping for a 5.0 so I wanted to know a bit more.
Thanks,
Mark
Thanks,
Mark
Luke9222
10-22-2015 11:55 PM
