Breakup at high RPM. Causes?
#22
Haha. Thanks. I'll head down to Autozone & get some carb cleaner & start there. 81, 82 I'm not going to worry about.
95- I'm going to see if they ran a wire from PIN 19 on the PCM to the FP relay. It primes & comes on fine so I'm guessing they did but I'll check it anyway. Does it go from PIN 19 to the yellow wire leading into the relay or the pnk/blk wire coming out of the relay?
#23
Alright. I cleaned out the MAF & tried checking the timing but it's dark & I nearly gave myself a seizure. I'll have to check that tomorrow.
It's driving a little better but it feels like it's missing.
I guess the next step is to order a new cap/rotor & new O2 sensors. Mine is running 3 wire O2 sensors. Do I need to run 4 wire due to the MAF conversion or do I stick with the 3 wire?
#24
Also when checking timing it helps to mark the balancer with white out..makes it SO much more easier to see!
#26
I'm assuming they're stock size injectors. The MAF I'll have to try to measure.
I bought the car over a year ago & it's exactly the same now as it was then. It wasn't until recently that I started having issues.
I'll have to check to see if there's an IAT/AIT sensor installed, along with the grounds on the manifold & heads. I'll also try to get a wire run from pin 19 to the FP relay. Which wire on the relay do I run the wire to? I'm guessing it's to the yellow wire going into the relay.
#27
I talked to my little brother & he said to pull the O2 sensors & try cleaning them with carb cleaner. He also said he'd check on the prices at his tech center to see if he can do better than $45/sensor for me.
I went ahead & ordered the FMS cap/rotor along with new wires.
Likely a stupid question- but are the MAP/MAF the same thing? I tried a google image search but all the images were of MAFs.
#28
Just my to-do list
81 & 82- Aftermarket headers. Ignore for now.
95- Check pin 19 for wire run to FP relay.
34- Clean/replace EGR/EVP sensors.
22- Cleaned MAF
29- VSS not connected. Ignore for now
41 & 91- Clean/replace O2 sensors. Clean injectors. Replace fuel pump.
-Check grounds on heads & IM.
-Install cap/rotor
-Check base timing
-Find out injectors & MAF size
-Check for AIT
-Check vacuum lines
22- Cleaned MAF
-Install cap/rotor
-Check base timing
-Check for AIT
-Check vacuum lines
#29
Doesn't look like the car has an IAT sensor. It goes filter, MAF, TB. On/near the TB there's the TPS, EGR, & IAC. So only those 4 sensors on the intake side of the car.
Today I cleaned the EGR & IAC. Used nearly a whole bottle of carb cleaner on the EGR but it seems to have been worth it. It's definitely idling better.
I picked up a 7/8th O2 sensor socket & injector cleaner from AutoZone. I was hoping that by having the aftermarket exhaust the O2 sensors wouldn't be rusted in but it looks like they're going to be a PITA.
It's definitely running better but it feels like it's pulling a lot of timing (possible the car is in limp mode?) or it has a slight miss.
