pulled codes, now how to fix them
I just pull some KOEO codes, I google'd what they mean, now how do I fix them?
KOEO:
54 - ACT sensor signal is greater than the Self-Test maximum of 4.6 volts.
Memory:
18 - IDM circuit failure or SPOUT circuit grounded.
63 - TPS circuit has intermittently failed below minimum 0.6 volts.
32 - EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
KOEO:
Memory:
looks like I opened pandoras box with this one
pulled the upper today, thinking I would just solder in a replacement plug and install a new line for the fuel canister(the original line was soft and gummy), well I broke a few vacuum lines and found out two injectors had cut wires and somehow it ran fine and gave me 26mpg. The EGR coolant lines are glued/gummed shut. Any tips/tricks I should know about before reassemble? What other things should I do before putting everything back together? Also can I reuse the upper-to-lower gasket?
TfcCDR
09-14-2015 12:08 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
