efi to carb ???
efi to carb ???
so im slowly but surely approaching the end of my project (key word is slowly) have a few conversion ?'s that i cant seem to find aswers too
1st im using the stock "in tank fuel pump going to holley regualtor
http://www.rpmcat.com/images/H19-12803.jpg
will this pump hold the pressure from the in tank fuel pump ??Also there are 2 arrows one left one right.....where does the return go where does the feed from the "in tank" pump go ands where does the feed to the carb go any help would be apprieciated
It has a been a couple of months since I helped a guy do this conversion. One on the side for sure goes to the carb. If the other arrow is pointing in the opposite flow direction, that is your return.
He had no trouble running a stock pump through stock 4cylinder car fuel lines. His motor had flat-top pistons with ported gt-40 heads.
If you get it installed and it is not enough, you can always try a fuel log to help it out like on the pic below.
I have doubts that the Holley regulator will work. It's only rated for low PSI. When I did mine, I consulted with a local speed shop, and they convinced me the Holley may work for a while, but probably won't last very long. I ended up with a Mallory pump (return style), which is rated to 50 PSI, works great, but it's triple the cost of the Holley.
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
