speedo question????
speedo question????
Did a V8 swap on a 91 2.3 LX. Used the 140 speedo& cable from the donor car but it reads 20 mph faster than the car is going!! Did not swap out rearend, could this be the reason for it reading faster?????
it doesn't matter what year or motor everything was... to a point
you need to know what drive gear is on the trans (6t 7t 8t)
to know what driven gear to use on the speedo cable
but if your an auto and 20 miles off you probably can't correct it, assuming your 20 mph OVER
an 8t output shaft for sure cannot correct that much, 7t is close , 6t will for sure
check your driven gear, it's c-clipped on the speedo cable, tell me the color of it and if you can count the teeth.
chances are you need to drop 5 teeth to be on and i doubt they make it
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
