Trick for the EGR solenoid falt code
Compleate a simple mood to trick the ECM in my 87 today and thought that I would share it. To start I am running an 87GT with a 90 harness (lots of repinning) and MAF. It runs great but due to the removeal of the smog system the ECM leaves the MIL light (installed in the tack) on at all times. I was able to trick the ECM by installing 3 75ohm 3 watt resisters. The process was simple. I removed the solenoids on the back of the passengers strut tower removed the plugs and soldered the risisters in line I then used glue lined heat shrink to cover the new resister. Less than $4.00 in parts and a little time and cleared 4 codes from the system.
lincolnshibuya
12-08-2015 04:37 PM
