BlackBetty93GT |
04-09-2010 10:28 PM |
Clutch Cable/Pedal help...Confused!
So I just replaced my clutch, pressure plate, throwout bearing and pilot bearing.
When I was first disconnecting the clutch cable i thought i heard something pop loose and all of a sudden I had alot of slack on the cable at the transmission. When that happened I looked under the dash at the pedals and didnt seem to see anything. Today when I put everything back together, I noticed the clutch cable must have disconnected from the quadrant behind the gas pedal. So I connected it and then connected the cable to the clutch fork and adjusted it to where it was when I took it apart. When i tried to drive it, if you start the car in first the car automatically is trying to pull forward and I cant get it out of gear to change gears.
Does anyone know what this sounds like?
