electric fan 88 gt
I have a programmable ecu to control the fan, but i got a taurus junkyard fan for $25 and a couple of automotive relays to control low and high speed and it works great, easy install too. I even still have the stock alternator and it still charges when on low with the headlights on. On high it draws from the battery, but that almost never comes on.
I have a triple core aluminum radiator from Summit and a Steeda radiator hold down bracket that needed to be modified to allow for the fan bracket to have a connection point at the top.
I've been running my e-fan for 2-3 weeks now and it's working great. Engine temps are rock-steady and I have no problems with using the A/C in hot weather anymore, even while sitting still.
If you haven't done a 3g alternator upgrade, you may want to do that... at low rpm's/idle the fan will come on more, and draw more current... with the stock alternator you'll probably drain your battery or kill the alternator.
Seanam
10-04-2015 10:15 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
