OBDll won't work!! Arghh
RE: OBDll won't work!! Arghh
ORIGINAL: Djs94stang
It will be marked on the emission tag that is under the hood. It is usually on the hood and will show a vacuum diagram. If it is OBDII it will be marked as OBDII certified. If it doesn't have this it is not OBD II.
If it's OBD1 it will have the plug under the hood. Also, you can get the readings with a jumper (like a paper clip) and an analog DC volt meter. The procedure and codes are shown here http://www.troublecodes.net/Ford/ and you connect it like this
09-01-2015 08:16 PM
