When going fast at normal temp engine pings
Whats the best way to use the seafoam?
I went by the directions on the can and to clean out the fuel injection. I was tought to disconnect the line going to the brake booster. And at the other end it is connected to the throttle body. Which has a vacume to it and I poored in a little seafoam mixed with gas at a time in that line that is conected to the throttle body. I just read the directions on the bottle of seafoam and it says to use 50% gas to 50% seafoam thats what I read. If going thru the throttle body is right do I use the whole can of seafoam this next time by it self. If this doesn't work I will switch back to the old air filter housing. Please let me know! Thanks!
Codes and cleaned Maf
There is no check engine light on and I'v been told if there is no check engine light there will be no codes other than that I have not checked my Maf that will be the next thing i do is check to see if its dirty and replace the housing and just to let you all know I used strait seafoam the whole can and It still was pinging and I put the seafoam thru the injection Unless pooring the seafoam in the gas tank is what you guys normaly do I will do that next. Thanks!
