Supercharger/Sct Problem
Heres the deal...Car was tuned with 10psi then taken to track and the sleeves on the supercharger discharge tube came unclamped. Also, changed coolant temp sensor b/c i seen it was cracked and belt for supercharger just to make it new. Now at track when i went back the psi is between 1-5psi and its like i'm running just all motor. Could the sct need retuning or ?? Confused on this one... Thanks
Are you using the same size belt. (slipping) If so your boost should be the same. Is your car running as good as it did with 10psi? If not your loosing boost.
Thanx-Muzzy 04 S281SC Convertible #355
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Ported and Polished SC by PSE
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
Chicane ss braded IC lines
Carbon fiber dash kit and shift ****
1 bottle of water wetter (haha)
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
loose belt?
Hi- did you fix the problem...
Muzzy
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
Muzzy
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
okay I tightend the belt down tighter and the problem still exist only putting out 4psi instead of 10psi.. Only thing I can think is maybe a retune since sleeves came off after that one run maybe, any other suggestions?
also, what brand belt are you using? i had the best luck with dayco polycog belts
i ended up buying this http://cgi.ebay.com/ebaymotors/Vorte...Q5fAccessories
to do belt swaps. then i got smart and got rid of the sc all together
