5.0 compatability question
First off, this is going into a 95% offroad Jeep build. I probably don't need more than a stock 5.0L, but...I found a pretty good deal on this stuff and there you go.
Anyway, here is what I bought, they are all but new...A Trick Flow Track Heat upper and lower intake set, a C&L 76mm MAF meter matched to 42 lb injectors, and a BBK cold air kit with a K&N filter.
As of now, I plan to add a set of GT40 heads and probably an low rpm torque cam to the mix.
Will these parts work together? Are the 42lb injectors going to be too much for an engine that is not forced induction?
Thanks
Thanks
