93 mustang 392 build
hey all,
Was wondering about Ford D392 I'm putting together with AFR 185 heads and a comp 282 1.6 roller rockers. Does anybody know the max push rod length i can go with this combo?
Thanks
RD
Thanks
RD
cam and heads are on the small side, but as far as your push rod question..there is no such thing as max push rod length to choose, you do not choose such, you measure for such with a length checker then based on the roll pattern on the valve tip you select the appropriate length according to your checker measurements
10-01-2015 09:11 PM
inyadreems
08-21-2015 09:10 AM
