Flaky white spark plugs
Adder, he does have a 100 shot on there, if he is going to use that, I would recommend 93. OP, just google octane ratings and start reading, you will get a better understanding. But these guys are right 110 is way too much for your engine, if it is leaded it can also damage the O2 sensors over time. Besides that, you are just waisting money. There is nothing magic in race gas that just gives you more power, or anything like that.
You can actually run into issues with too high of an octane, even when on the bottle. Here's an interesting article from Pro Systems on that. http://www.prosystemsracing.com/scoop040909.html And keep in mind that if you start to get backfiring from too high of an octane....on nitrous...you can get exhaust issues. Worst case scenario you could get an effective lean missfire from too high an octane and then on the next intake stroke you possibly could end up with an intake backfire on nitrous. Bad news.
I run 91 in mine with 9.44:1, but it's also California fuel which is highly oxygenated and has tons of additives, but I also run a lean fuel mix with aggressive timing in an area where summer temps can sometimes exceed 110 F.
With nitrous you may be better off running on the rich side with the shot than running higher octane, depending on fuel availability. A mix of pump and 100 would be ok for a small shot, but I'd be wary of running even a 110/pump mix with a small shot. And even if you don't get backfiring, if you end up with fuel burning in the exhaust system it can be bad for O2 sensors due to the excessive heat they'll see, and they can get sooted up.
Some of them do, yeah. 110 octane is not 110 octane. Some have lead, some don't, and depending on what was used in the blending, different suppliers can have completely different jetting and timing requirements. And of course if they have lead and the jetting is wrong you can also get lead fouling of the plugs as well.
Part of the problem the op has may also be specific gravity of the fuel. Many race fuels have varying specific gravities for the same octane, so using 110 octane from a different supplier with a different specific gravity can throw the afr all out of whack.
i run 110 cam2 in my power washer and my leaf blower at my shop drained from my bosses 1000hp supra. Works great! why would you run race gas?? are you racing? i dont mean to put you on the spot or anything but i agree with everyone else it wont burn youll foul out plugs and leave crap in cylinders.
Ok again I dont have o2 ssnsors,but thanks for all the info,and yes I race this car almost every weekend,well until this happend.Just thought I was doing the right thing by running the 110 cam 2,but obviously not.Still havent got to work on it yet I will post as soon as I try something.
update
Pulled the carb and cleaned it all up,found a piece of something in one of the jets,thought that was the problem but nope.Gonna drain fuel tomorrow and put pump gas in it.Its such the slightest break up at all rpm's.My buddy thought I was on crack but once he went for a ride he heard it.Could a bad ignition box be a culprit?Iam running the summit racing box which is Mallory components,any thoughts?Also with the motor breaking in would that cause anything to act up?
