Overheating
Overheating
I have a 94 ford mustang gt 5.0 with vortec supercharger, new water pump, new griffin radiator & 2 fans (1 in front and 1 in back) we have tried 195 & 185 deg. thermostat . It did run cooler when we put a center hole in the thermsotat but we figured that wouldnt last long. Any ideas on how to get it to run cooler with the thermostat in it? Its running at around 200-210. I know thats not bad but once it gets there it just keeps climbing.Any ideas would be greatly appreciated.
Sounds like you have replaced everything that would cause it to over heat. One question the fans are new, but how about the device that closes to turn them on at the right temperature. The fans do run is the question? Good luck.
stock programing calls the fan on @ 208 and off @ 204 so if you say it runs 200-210 thats right in ball park.
i know everyone says this but with a tune (quarterhorse and binary editor) you can call your fan on @ any temp you want... not to mention tune every aspect of your vehicle.. even shut off the annoying mil light for no egr and air pump
ps good call mattdel
take the fan off the front of the radiator it is not helping it is actually hurting since you have one behind the radiator too. it restricting airflow because it is blocking space for air to flow throuh even though it is pushing air it isnt helping.
mungodrums
09-29-2015 09:18 PM
yourmom6990
09-14-2015 10:52 PM
